GSXR 600 year compatibility
I am running 2006-07 GSXR 600 engines currently and I am wondering what the compatibility to newer engines would be. The 06-07 engines seem to be getting harder to find so if i could move to 08-09 or newer without much work that would be good to know.
I believe the oil pans and headers should swap fine.
The ECUs look the same so maybe i could just swap out the right year's ecu? i havent looked at a wiring diagram to see if the pinouts are different.
Anything else with the electrical system that wouldnt be interchangeable?
Are the mounting points/physical dimensions the same? just looking at pictures they look almost the exact same.
thank you,
