What is this pin mechanism?
They are called Ball Lock Pins or PIP Pins...............Carr Lane Mfg. or McMaster Carr
I thought so but cannot find a manufacturer that makes that style of handle.
I listed two above, in fact I just bought a bunch of pins, same style, from Carr Lane Mfg. in St. Louis
That's because it's not from Carr-lane or Mcmaster; They are Alcoa Cam-loc fasteners with a custom pull-ring handle. Crawford may have a part number.
http://www.afsrcamloc.net/
http://www.afsrcamloc.net/prod1.php?lang=en
I have a car with what I guess is 2600 or 2700 series cam loc fasteners. It's a knurled stud head. It's functional with gloves, but the pin is retained on the cockpit surround -- it doesn't come free like a pip pin would. That's actually great as you don't have a small fastener to get lost, but OTOH the pointy end of the fastener scrapes the tub during install/removal of the surround. It requires care during install/removal to avoid the scraping. I haven't tried clear or other tape on the area yet but I suspect the pin would cut through it too quickly anyway. Anyway I have a car with scraped paint all over the area as testament to the issue so I was looking for something not-a-camloc.
Also having used simple clevis pins with the reusable cotter pin clip I think I prefer a loose pin than a captive pin.
I know, of all the stupid useless things to care about this is pretty low. But I'm fitting a new cockpit surround now and so it's time well spent.
I did just find something called a double acting pin. It's like a pip pin but you can just pull the handle and it releases. That seems pretty glove friendly so I think I'll try it out.
I have used them in a few designs at my full time nuclear job. The cam handles were the style we used for positioning a hydraulic drill boring a ~ 4 and 1/2" hole and 5.5" weld prep. They weren't taking the thrust load, but they were still subjected to all of the vibration. Never came loose, and were quick to deploy in the field. I would give them a shot if I had a head surround in my F500.
