1 Attachment(s)
Looking for set of wheels for Lola T91/50
I'd like to pick up a 3rd set of wheels, I like to have 2 sets of slicks and 1 set of rains mounted.
Where does one find wheels for an F3000?
I have two sets now, one is BBS and one is Work. The Work wheels have tires mounted, so I can't pull any numbers off the wheels and the wheel centers are not labeled or stamped with any part numbers. They have 20 bolts holding the assembly together. The BBS are 12 bolts.
BBS use the same inner hoop on all 4 corners:
Part No: 01.16.014 0906 // Size: R-TI40 8-1/2 x 13 H
BBS front outer Part No: 01.12.001 0906 // Size: R-TA35 2 x 13 H
BBS front center stamped 0263254
* I have 3 BBS front outer and one has a p/n that ends in 0507 instead of 0906. I don't know that it makes any difference.
BBS rear outer Part No: 01.12.008 1008 // Size: R-TA35 5-1/2 x 13 H
** The Work wheels are 6-1/2" outer, and I'd really like to make my next set of wheels match that width. 15" overall will be for dry tires, 14" for rains.
BBS rear center stamped 0263255
Front drive pin circle 3.5" dia ; Rear drive pin circle 3.70" dia (pins are 0.49" dia)
Both front and rear centers have a BBS standard qty 12 x 6mm bolt mounting circle on 250mm PCD with 235mm bore hole in the rim halveshttps://www.apexspeed.com/forums/att...id=92924&stc=1
