UPDATE 11/2/20 - SOLD. Thanks Apex!
Price: $8,500
Nationally competitive road race F500
Meticulously maintained by original owner since new
Four top-10 Runoffs finishes (6th at Daytona), with overweight out-of-shape driver!
142.8 mph through the speed trap at Daytona Runoffs
Continually upgraded for speed and handling, but still uses mostly factory Red Devil parts
Full Brad Hulings set up: 593 engine, pipe, MPEM, carbs, clutches
Custom fuel cell (larger capacity for 593)
Ackerman-correcting steering upgrade
Custom watts link (ball bearings instead of brass bushing)
Lightened and balanced rear axle gear
Upgraded 2008+ Red Devil rear uprights (gear ratio can be changed WITHOUT resetting suspension)
Custom diffuser
Redesigned ducts and custom air intakes for radiators (-15 degrees)
AIM XG Log data system with beacon
Wired transponder (no subscription)
New Ron Davis radiators (2015) with honeycomb protective covering
Aluminum water pipes used wherever possible for heat dissipation
All fuel lines covered with fire sleeve
Custom pipe mount (does not break from vibration)
Driver-operated primer instead of chokes
Extra sidepod tubing and aluminum panels for driver protection
Tires are from 2019 Runoffs
New nose (2020)
New Shorai lithium iron battery (2020), less than 1 lb
Belts good through 2021
New parts for 2019 Runoffs
Brad Hulings engine (full rebuild with new crank)
NOS Arctic Cat roller clutch (new, not rebuilt)
Clutch belt
Drive belt
Front brake rotors
Front wheel bearings
Rear axle bearings
Shock pucks
Many suspension rod bearings
Partial rewire
Spare parts that come with car
Car lift (see pictures)
2nd Set of standard wheels
Set of rare rain wheels with mounted rain tires
Carb jets
Extra clutch spring
Longacre relative air density gauge
New rear axle
New shock pucks (4)
New cockpit brake bias adjuster kit
New Hulings front engine damper kit
New clutch belt
New drive belt
New bearings for custom watts link
Sensors and wiring to add EGT to data system
Two jackshaft gears (to change gear ratio)
Ski Doo factory service manual for engine
Extra Polaris primary clutch (good used condition)
Extra Arctic Cat secondary clutch (good used condition)
New pictures will be uploaded once the new nose is painted.
Delivery negotiable within 300 miles of Charlotte, NC
I’m sure there are things I’ve forgotten, so I will be updating the ad as appropriate. Please PM me if interested.
Cory
https://live.staticflickr.com/65535/...66dfebe2_n.jpgKen Brown Comp Photo ND-0332-11 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...c996bda5_n.jpgKen Brown Comp Photo ND-2253-11 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...8286273c_n.jpgIMG_3830 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...0f37a565_n.jpgIMG_3829 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...afaa8ff0_n.jpgIMG_3831 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...2efa4cd5_n.jpgIMG_3832 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...1d9c2856_n.jpgIMG_3834 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...8dcb04fb_n.jpgIMG_3833 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...a194da47_n.jpgIMG_3835 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...3d8a701f_n.jpgIMG_3836 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...86818c37_n.jpgIMG_3838 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...6a985798_n.jpgIMG_3837 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...340a751a_n.jpgIMG_3839 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...7db9d851_n.jpgIMG_3843 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...a2119a82_n.jpgIMG_3848 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...056b7928_n.jpgIMG_3845 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...2f20e52e_n.jpgIMG_3844 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...828d5e14_n.jpgIMG_3840 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...b188ecd0_n.jpgIMG_3841 by cory58f5, on Flickr
https://live.staticflickr.com/65535/...295e4092_n.jpgIMG_3847 by cory58f5, on Flickr
