1 Attachment(s)
How to remove an Earl's OE Fuel Line EFI Quick Connect?
I have one of these installed on a Suzuki fuel pump (output line) and would like to use it somewhere else, but I haven't been able to figure out how to remove it.
I have the little tethered key/retainer thingy, but not sure if that is what I need to release it off of the metal tube,and how.
https://www.apexspeed.com/forums/att...id=95559&stc=1
Here's a description of the product:
Earl's Quick Connect Adapter fittings are a slick easy way to use AN plumbing with late model OE fuel rails & fuel lines. Each quick connect uses two reusable metal retainers that won't break or melt. The secondary retaining clip is attached to the fitting on a tether chain.
Features:
- One hand “click” connection to OE line
- Metal internal and external retainer provides a reliable & reusable fuel connection that cannot snap loose or melt like some plastic retainers
- O-ring material developed specifically for the same application on factory vehicles to tolerate today’s fuel additives and E85
- Tether chain keeps secondary retainer clip attached to the adapter so it is always handy (installed retainer can also be safety wired to adapter for additional safety)
- Fits Most Vehicles w/ 5/16" Fuel Rail - SAE Standard Connection
