For sale chassis T87-1, lay down model with 494 Non Rave. Original "Hinged chassis" was repaired, reinforced, and wheel base was lengthened to 79.5 inches, when converted to the Rotax engine. Many updates that include: New Polaris primary and Artic Cat roller secondary from QRE. Poly chain drive with new spare belt. New custom 4130 rear axle. Four gallon aluminum tank.
Final drive ratio is set up for road racing as I build as a track day car. Should be easy to change sprockets to achieve auto cross ratios. It has one set of mounted R25s, one set of mounted rains, 2 sets of scuffed R25s, plus includes many spares and tools. The car has 7 track days and 2 autocrosses since rebuild and has been proven reliable and good handling. I have original log books, and car history.
Estimated weight in the logbook is 570 lbs. without fuel and driver. Even with the mods I would still think it would still be under 600 lbm
I also have 1 440 Kawi for sale:
Complete engine has been Sold
Still available, older but un fired Quadrini rebuild with receipt (I verified it with Mike) with a PWS starter, no carbs, water pump, partial electronics.
Asking $2500 for the car and spares.
$200 for each engine.
http://www.apexspeed.com/forums/atta...id=70894&stc=1http://www.apexspeed.com/forums/atta...id=70895&stc=1http://www.apexspeed.com/forums/atta...id=70896&stc=1http://www.apexspeed.com/forums/atta...id=70897&stc=1
http://www.apexspeed.com/forums/atta...id=71614&stc=1http://www.apexspeed.com/forums/atta...id=71615&stc=1http://www.apexspeed.com/forums/atta...id=71616&stc=1http://www.apexspeed.com/forums/atta...id=71617&stc=1http://www.apexspeed.com/forums/atta...id=71618&stc=1
