FF wheels needed - Sources?
Need new wheels. 3 3/4" dia. bolt pattern. Same offset as the original FF steel wheels. (Is that a commonly known offset, or do I need to measure?) I'm on a budget, so steel is probably fine unless I can find some good, not-expensive aluminum ones. Can anyone recommend sources where I can start looking for and pricing such wheels?
Thanks!
Traci
vintage FF may require steel wheels
Traci
Since you posted in the 'vintage FF' section, I will assume that is what these will be going on.
Be aware that many (most?) vintage classes require steel wheels on FF. Luckily our area (PNW) has loosened this requirement to allow same with alloy wheels.....
Good luck!
