Is this GCR spec a typo??
Page 303 of the 2016 GCR includes the following specs for the Kent motor CP pistons:
Bowl depth: .470" minimum
Centerline of wrist pin to crown: 1.702" +/- .002"
Overall height: 2.80"
Since the CP pistons are ~.505" bowl depth, I assume the .470" minimum is an allowance to add unswept volume for over-decked blocks. Is that the intent? If so, that would reduce the overall height by .035", so the overall height should read 2.80" +0/-.035". Then the pin height spec should read 1.737" +.002/-.035; in that context, it can't be 1.702" +/-.002".
Can someone shed some light ?
