Car recently got serviced (Fluids, Front Rotors, New Brake Pads, Rescaled, Carbon Composite Fixes)
Engine was fully rebuild by Spring Mountain only 2.7 hours on the engine
GDU rebuild with the same amount of hours as engine
I have receipts for all the above work and will include spare set of wheels with barely used rains, new starter and some random parts.
Specs:
1500cc Suzuki Engine
Dual-Seat
Paddle-Shift
Aluminum Bi-plane Rear With w/ Carbon Fiber Dive Planes
Intrax Tripple Adjustable Shocks
Carbon Composite Bi-plane Rear Wing with End Plates & Wing Support
Carbon Composite Twin Front Dive Planes
AIM Sports MXL Pista Dash
AIM SmartyCam GP HD v2.2
AIM GPS09 Module
AIM Data Hub
Manual Fire Extinguisher
Front & Rear Lights
Radio Ready
Transponder
Front & Rear Brake Sensors
Dry Sump
Hot Weather Cooling System
Radical One Piece Wide Wheel Set
Quaife Differential Gear drive unit
Le Mans Style Carbon Rear View Mirrors
Life Engine Management System
Twin Battery 24V Starting/Charging System
Driver Side Head Restraint
Sabelt Silver Series A622 Formula 2×2 FIA Harness (both sides, exp. 2026)
Oil Heater with Easy Access (really helps to lower engine hours)
Asking $59,995USD
https://www.apexspeed.com/forums/att...d=104058&stc=1https://www.apexspeed.com/forums/att...d=104059&stc=1https://www.apexspeed.com/forums/att...d=104060&stc=1
