Lola T94/00 Suspension Questions
Hello,
I have a Lola T94/00 that I'm slowly piecing together parts for to get it back on track eventually. I'm trying to decide what shocks to go with as it currently has stiff beams installed. I have been working out of state the last few months, and havent been able to spend much time other then ordering parts, so forgive me for asking what might amount to stupid questions.
I'm thinking a TT40 or TT44 should work, but I haven't been able to find much definitive info on travel length and shock size that will work for these. Before I can get home to take it apart and start measuring, I figured I would check in here to see if anyone knew off the top of their head what might work. I've found a set that are 10.2" and 11.5" long with 2.25" springs that Im hoping might do the job.
Also, I've seen pictures of them being run with both remote reservoirs and with standard ones fixed on the shock body. It seems like it would be a tight fit without remotes, but once again, I haven't been able to get a set to try it out. Any thoughts?
Regards,
Dylan
