1 Attachment(s)
Need longer shifter arm (and Translogic Power Shifter)
I bought a used Translogic PSR Pro+ shifter and the instructions suggest a longer 65mm shifter arm.
Does anyone know where I can get one, or a steel one I can use to make one? I heard off-road bikes often use steel shifter arms but I'm not sure if I need a specific diameter or spline count. I haven't yet found that information.
I have a Gen 2 Suzuki Hayabusa.
I'm also wondering if any of you are using this shifter and can share your thoughts about it - pros and cons, suggestions, etc. The manual I got doesn't seem to include everything.
Thank you.
Russ
https://www.apexspeed.com/forums/att...id=93916&stc=1
