7 Attachment(s)
2000 Novakar J9 for sale
Last raced back in 2012 at Waterford Hills in MI. Priorities have changed and this car must go. Needs a few things before it can race but it is a strong foundation. The car was painstakingly prepared and set up, which is one of the reasons I was on the podium a couple of times in my rookie year of open-wheel racing.
DETAILED PICTURES in Google Album: https://photos.app.goo.gl/3RKvd6rHuwL1EQgK7
Features:
- Rotax 494 engine w/electric start & airbox
- Hulings Clutches
- 50mm chromoly rear axle
- AP Racing Brake m/c & dual front Wilwood calipers with Tilton cockpit brake bias adjustment
- 5lb Halon Fire System
- AIM Mychron 3 datalogger & AMB transponder
- SCCA & Waterford Hills Logbooks with full history
Before I went through drivers school and ran 3 race weekends at Waterford Hills in 2012, the following work was completed:
- New belly pan, right sidepod & carbon diffuser (diffuser is practically brand new)
- 1 season old Brad Hulings clutches and new drive belt
- New Jackshaft bearing housings and bearings
- New 50mm rear axle made from 0.188" wall 4130 chromoly steel tubing
- New Acculoc rear axle bearings (they clamp on solidly to the axle tube)
- New 520 O-ring chain, front sprocket & 7075 rear sprocket (15/47 gear ratio)
- New Mikuni high-flow fuel pump
- New Suspension rubber pucks
- All rod-ends in the front & rear suspension replaced
Spares / special tools:
- 3 full sets of Keizer/Kodiak wheels with mounted slicks and rains. Several rim halves and center rings
- Quick jack & Gantry with electric hoist (red jackstands shown in pic not included)
- Chain & jackshaft tools
- Engine leakdown tester
- Setup jigs for ride height and wheel alignment
- Boxful of odds and ends, radiator, chains, fasteners, brake calipers, pads etc.
- Old 1.25" rear axle assembly
The car will need the following work before it can be on track:
- Belts (they expired in 2014)
- Fuel cell (leaks at filler but possibly repairable by FuelSafe)
- Left front hub (one of the legs broke off, better to replace both fronts)
- Bodywork repairs (Nose and left sidepod)
- Battery
My asking price of $5000 hopefully reflects the condition of the car and my desire for a quick sale. Located in South-East Michigan.
I don't check this forum often, so best way to reach me would be a phone call or text at 231-715-1505. Thanks for looking!
https://www.apexspeed.com/forums/att...id=82698&stc=1https://www.apexspeed.com/forums/att...id=82699&stc=1
https://www.apexspeed.com/forums/att...id=82693&stc=1https://www.apexspeed.com/forums/att...id=82694&stc=1https://www.apexspeed.com/forums/att...id=82696&stc=1https://www.apexspeed.com/forums/att...id=82697&stc=1https://www.apexspeed.com/forums/att...id=82695&stc=1
I have received a 10% good faith deposit from a buyer. Sold pending full payment and local pickup. Thanks Apexspeed!
Because whats better than one Novakar??? lol
