New tires (might still need to adjust ride height for them).
Unused rain tires.
Extra set of rims.
Recently replaced the rear brake pads (no laps on them) and have an extra set for the front.
The onboard computer is ready for laptop connection, If you ask nicely, I might include the surface tablet I used with it.
Things that you might want to fix/change
Cluch pedal has a very minor leak, prob needs an oring replaced the leak is on a level where it takes weeks or months for the reserver to empy.
Front damper cover lock screw is gone, as you can see on my pics/vids I hold it down with ducktape, cause you to know ducktape is always the answer
Front Splitter aluminum plate is bent, you might be able to straighten or should be and easy replacment. (you can also run as it if you are not super compettetive)
Tracktion control has been deleted
Buyer also has the option of purchasing an incredibly accurate PFM motion simulator.
Simulator details
10k (or 5k without the motion system)
Built on PFM tub
D-Box motion actuators
Direct drive wheel bas
Load cell brake pedal
Sequential Stick (located in the same place as in the PFM)
Paddle shifters on the wheel
LCD Dash in the wheel, the dashboard can be changed to be more like the PFM.
