10 Attachment(s)
Shermet Warrior 1915cc Vee $6,000
Car and trailer are located in south Texas, 78387. PM or even better call/text to 361-215-7986
- 1915cc, built by a vee regular here on apexspeed with many goodies. Penn Grade (Brad Penn) break in oil used, and Penn Grade 10w40 used thereafter, pressures and temperatures in check with no exceptions. About 4hrs runtime estimated on this car as-is.
- Dual Dellorto 40 DRLA carbs, Pertronix electronic ignition, rotary electric fuel pump, deep sump with large external filter. CB Performance breather.
- Fuelsafe CB304 6-gallon fuel cell
- Doghouse cooling shroud, oil cooler... cools and charges itself with no issue.
- Offset bushings with crack-inspected spindles, new shocks, heims, rods, Zero-roll rear setup
- New shifting apex joints and heims. Shifter is positive and tight, has reverse lockout
- Fitted seat, very comfortable
- Tach, Oil pressure, Oil Temperature, and CHT gauge. Electronic rev limiter and fuel pump safety cut-off.
- New Shorai battery
- Disk brakes all around
- Extra 14x8 steel wheels, current set are 14x6 mag, Hankook Ventus Z214 C71 tires
- $6,000
The car is very well tuned and runs perfectly. I'm big on feel and feedback, and this car delivers. ;)
Trailer also available - 2014 Continental Cargo 7x14 available for an additional $2500 with sale of the car, $8500 for both. E-track, 110v lighting and outlet, winch with remote for super easy solo loading/unloading.
